Displays the MPLS contents of the IP routing table.
| lsp_name | Specifies an LSP name. |
| vlan_name | Specifies a VLAN name. |
| permanent | Specifies permanent routing. |
| ip_address | Specifies an IP address. |
| netmask | Specifies a subnet mask. |
| unicast | Displays unicast routes. |
| vrname | Specifies a VR or VRF. |
N/A.
A c flag in the Flags column indicates a compressed route resulting from enabling compression using the enable iproute compression command. The total number of compressed routes is also shown.
All routes that are provided to the FIB display the f flag.
If you do not specify a VR or VRF, the command applies to the current VR context.
The following example example displays detailed information about all IP routing:
Switch.3 # show iproute mpls
This command was first available in ExtremeXOS 12.2.2.
